Question regarding CISCO 6921 voicemail
Pragash22
Hi All
In  cisco 6921 a message in the display suddenly displayed saying New  Voicemail, but I havent configured any voice mail in the call manager?
Also red light in the reciever steadily glows. I tried to read that voice mail, bt still that red light steadly glows
Thanks and Regards
Pragash
5 Replies 5
Manish Gogna
Hi Pragash,
Did you check what is configured under "Voice Mail Profile" setting on the directory number for 6921?
Also, when you try to listen to the message what exactly happens, are you able to listen to it or not?
As per the following
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/ip_phones/6921_6941/english/user/guide/6921_41.html#wp90757
"When you have one or more new messages, the  message-waiting indicator (MWI) on your handset is lit. The MWI works  only if the MWI is configured on your phone."
Manish
Thanks for your reply
I can listen to the recording of voice mail (default voice mail IVR) and also Voice Mail Profile - None.
There is no recording available, but I can hear the recording "Cisco unity......" (cannot hear properly, its breaking)
When I try listening to the message just keeping me in hold and could listen to the message. (We havent configured voice mail)
Have you syncronized the MWI ports on the Voice mail server and have you tried dialling the MWI Off ext from the phone?
http://www.cisco.com/en/US/products/ps6509/products_tech_note09186a0080b2ed0b.shtml
http://www.learnios.com/viewtopic.php?f=4&t=31175
Best Regards
Hi Hermanus
I guess your 2nd link will help me to sought out this problem, because I remember that user said that he pressed some thing after that the voice mail started to glow. I am at home now a'll go to office tommarrow and try put that thanks.
Thanks so much for your help.
It might be an alternate MWI for some other DN
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
