10-29-2013 04:55 PM - edited 03-16-2019 08:08 PM
Correction, I mean 2901 not the 2921. Will 2901 be able to be both a voice gateway for PSTN and normall router for data?
hey, there
I have a remote site deployment coming up and we bought a 2921 router as voice gateway for the 24 local phones. I am thinking to use it also as router on site to talk back to hq. so we donot have to buy another gateway for the new branch. Will this be recommended from performance standpoint? we are using mgcp with srst on local gateways.
I also have another question about cucm. the hq has 2 cucm ( 1 subscriber and 1 publisher). we are planning to add another subscriber into cluster as company growth and also better call processing redundancy. but how should I implement publisher redundancy?
thanks,
Shuai
Solved! Go to Solution.
10-29-2013 09:46 PM
You can only have 1 publisher in the cluster, that is how the Informix DB works. If and when your publisher fails, it will need to replaced/restored.
If you register your remote phones on sub1 and backup/fail over to sub2, that would give you full redundancy. If you are using SRST as backup locally, personally I wouldnt bother using MGCP at all, because you will still need to configure dial peers. just use H323 on your gateway.
Please remember to rate useful posts, by clicking on the stars below.
10-29-2013 05:04 PM
2921 router
This will work just fine for 24 local phone
My take would be a 1:2
1 x Pub
2 x Sub
10-29-2013 05:14 PM
So the 2921 router is fine as router for data traffic and also a voice gateway to PSTN?
What I mean by publish redudancy is: if the publish went down for whatever reason, I have a backup publish kick in automatically. I know 1:1 and 2:1 redundancy setup but I never saw any information about just publish redundancy.
10-29-2013 09:46 PM
10-30-2013 04:50 AM
So I just have to backup the publisher, in case restore is needed.
We have been using MGCP for HQ and other 2 branches. So we probably just keep it for now.
Thanks,.
10-30-2013 06:59 AM
You want to backup your whole cluster and not just the PUB.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
