11-11-2020 09:00 AM
Does a customer need to have a CUBE license to support SIP dial peers?
Solved! Go to Solution.
11-11-2020 09:26 AM
No, you need the UC/Voice license for UC related configuration like voice dial peers, and you need CUBE licenses for the CUBE sessions.
11-11-2020 09:26 AM
11-11-2020 09:31 AM
If you are talking about configuring SIP dial peers in general, no you do not need a CUBE license. You can even enable inbound-to-outbound SIP dial peer connections with "allow-connections sip to sip" without a CUBE license
There is a specific CUBE feature set, though, that is enabled when licensed. Here is a link to the CUBE v14 Data Sheet which talks about that in more detail.
Cisco Unified Border Element Version 14 Data Sheet
Maren
