06-10-2018 09:14 PM - edited 03-18-2019 12:26 PM
Hi Pals,
I am trying to create a conference in my 9971 Phone, but the "conference button" does not work after 3 party conference (built-in conference). I have a 7941 in CME as well. 7941 work great no problem.
This is the problem:
SCR1(config)#voice register global SCR1(config-register-global)#con? % Unrecognized command SCR1(config-register-global)#con ? % Unrecognized command SCR1(config-register-global)#c? call-feature-uri call-forward camera create SCR1(config-register-global)#conference hardware ^ % Invalid input detected at '^' marker. SCR1(config-register-global)#
This is my config
ip dhcp excluded-address 192.168.3.1 192.168.3.100 ! ip dhcp pool VOICE network 192.168.3.0 255.255.255.0 domain-name sc.local default-router 192.168.3.254 option 150 ip 192.168.2.254 ! ! voice service voip no ip address trusted authenticate allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip sip bind control source-interface Loopback0 bind media source-interface Loopback0 registrar server ! ! voice register global mode cme source-address 192.168.2.254 port 5060 max-dn 10 max-pool 10 authenticate register voicemail 3050 tftp-path flash: create profile sync 0001688300260208 camera video ! voice register dn 1 number 3002 call-forward b2bua noan 3050 timeout 8 name SC Phone 2 mwi ! voice register pool 1 id mac 580A.2099.3C0D type 9971 number 1 dn 1 dtmf-relay rtp-nte codec g711ulaw ! ! ! ! voice-card 0 dsp services dspfarm ! ! controller T1 0/2/0 cablelength long 0db pri-group timeslots 1-24 ! controller T1 0/2/1 cablelength long 0db ! ! ! interface Loopback0 ip address 192.168.2.254 255.255.255.0 ! ! interface Service-Engine1/0 ip unnumbered Loopback0 service-module ip address 192.168.2.253 255.255.255.0 service-module ip default-gateway 192.168.2.254 ! router ospf 1 network 0.0.0.0 255.255.255.255 area 0 ! ! ip route 192.168.2.253 255.255.255.255 Service-Engine1/0 ! ! control-plane ! ! ! mgcp profile default ! sccp local Loopback0 sccp ccm 192.168.2.254 identifier 1 version 7.0 sccp ! sccp ccm group 1 associate ccm 1 priority 1 associate profile 1 register TRANSCODE associate profile 2 register CONFERENCE ! dspfarm profile 1 transcode codec g711ulaw codec g711alaw codec g729ar8 codec g729abr8 maximum sessions 1 associate application SCCP ! dspfarm profile 2 conference codec g729br8 codec g729r8 codec g729abr8 codec g729ar8 codec g711alaw codec g711ulaw maximum sessions 1 associate application SCCP ! dial-peer voice 3050 voip destination-pattern ^3050$ session protocol sipv2 session target ipv4:192.168.2.253 dtmf-relay rtp-nte codec g711ulaw no vad ! dial-peer voice 4001 pots destination-pattern 4001 port 0/2/0:23 forward-digits all ! dial-peer voice 50 voip incoming called-number . codec g711ulaw ! dial-peer voice 1 pots incoming called-number . ! ! sip-ua mwi-server ipv4:192.168.2.253 expires 3600 port 5060 transport tcp unsolicited ! ! ! telephony-service sdspfarm units 2 sdspfarm tag 1 TRANSCODE sdspfarm tag 2 CONFERENCE conference hardware max-ephones 10 max-dn 10 ip source-address 192.168.2.254 port 2000 max-conferences 8 gain -6 transfer-system full-consult create cnf-files version-stamp Jan 01 2002 00:00:00 ! ! ephone-dn 1 octo-line number 3001 description +7003001 name SC Phone 1 call-forward noan 3050 timeout 8 mwi sip ! ! ephone-dn 10 octo-line number A1 conference ad-hoc ! ! ephone 1 device-security-mode none mac-address 001E.F728.DEC3 type 7941 button 1:1
This is the IOS Version/CME Version
SCR1#show telephony-service CONFIG (Version=8.6) ===================== Version 8.6 SCR1#show ver Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(4)M7, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport
Thank you!
06-11-2018 07:02 AM
