"Enter Your ID" when external call transfer to voicemail
Hasrat Bhanot
When external calls transfer to voicemail caller get "Enter Your ID" not the greeting, calling internally works fine
Please see the attached config
Andrew West
Level 4
Level 4
I assume that you have the mailbox built for the number, assuming the PSTN based call comes in the same way...
The following from Unity Tools gives you a good way to see in real time what is going on assuming you dont know where to pull the logs from RTMT: http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Sorry forgot to mention it is Call manager express
