05-07-2019 12:26 PM
Running CUCM 11.0.1 and while trying to upload a .cop file for a new device type we receive the error "No valid upgrade options were found" and shows "Name does not match any filter pattern". It shows the time the file was last modified at the Option Name.
See attachment. File name is "cmterm-MH_iOS_11.0v1-SIP.k3.cop.sgn" (Also removed .sgn on the SFTP and the result was the same)
Solved! Go to Solution.
05-11-2019 04:45 PM
05-07-2019 10:42 PM
05-11-2019 04:45 PM
05-13-2019 06:49 AM
05-13-2019 07:40 AM
10.x and above already have those keys installed by default, that file is only required on systems below 10.x that didn't include the keys.
05-13-2019 08:00 AM
05-13-2019 08:16 AM
05-13-2019 08:27 AM
No, because they are already in the OS, just as there was another key in 9.x and below you used, without even knowing.
If you lacked those keys, they would NOT prevent you from seeing the file on the TFTP, it would error out during the actual install process when it tried to validate the file actually came from Cisco and was signed with that key.
05-13-2019 08:53 AM
05-13-2019 09:04 AM
If you've validated that you are indeed able to read from the right directory, then the problem might be the file itself, there are some rules in the naming of the files that are used to validate the file is for CUCM, I'd reach out to whoever gave you that file and make sure the name of the file was not modified, if it was, that's most likely the reason CUCM is not recognizing it.
That doesn't seem to be a file you can just download, so also make sure that is indeed meant to be used with your CUCM version.
05-13-2019 09:27 AM
05-16-2019 11:58 AM
