08-28-2018 12:11 PM - edited 03-17-2019 01:24 PM
Hello all,
I have this weird issue - I tried to install newer 8831 phone firmware file on CUCM 10.5 cluster.
I have successfully installed on CUCM-sub. The CUCM Pub shows " No valid upgrade options were found" while installing 8831 phone firmware.
CUCM Cluster version: 10.5 ; 1 Pub and 1 Sub
Firmware Installation procedure:
https://www.cisco.com/web/software/282074288/118220/cmterm-8831-sip.9-3-3-TO-10-3-1-v2-readme.html
Any thoughts?
Your feedback is appreciated.
Master001
08-28-2018 12:35 PM
08-28-2018 11:45 PM
Hi ,
Make sure the cop file is lying in correct path where sftp is running.
regds,
aman
08-29-2018 07:20 AM
It is .cop file. The SFTP path is correct - I have successfully installed the firmware on CUCM-SUB in the same cluster via same method ( i.e. SFTP server). And this is really confusing me.
Master001
08-29-2018 07:25 AM
04-20-2019 12:11 PM
04-20-2019 12:15 PM
Once you put cop file path in sftp in Create a new folder (admin) puts that cop file in admin folder then you are able to upgrade.
Thanks..
Sadav Ansari
04-20-2019 11:22 PM
10-06-2020 01:47 PM
Sorry this is quite old post but did you manage to resolve the issue on Publisher? I am having same issue where I can successfully installed firmware on Subscriber but Publisher is causing the problem.
Santosh
10-06-2020 05:36 PM
I
10.x and above already have those keys installed by default, that file is only required on systems below 10.x that didn't include the keys. If below 10.x What SFTP Software are you using. Make sure the SFTP Root directory is pointing to the folder where you have COP File. NO Need to modify the cop file name.
