10-01-2013 07:38 AM - edited 03-16-2019 07:37 PM
Using CUCM 9.1 and recently received a replacement 7940G phone back from Cisco. However, when it attempts to boot it stops and reports "tftp file not found". I have read that this could be related to a firmware issue, but how do I tell what firmware is actually running currently and then update only this particular phone if that is the case?. Any help would be greatly appreciated.
R/
David
Solved! Go to Solution.
10-02-2013 05:23 AM
Hi David,
Good idea my friend I'm thinking 8-1-1 would be
a reasonable choice here. Your current CUCM device
defaults are probably trying to load an 8-1-2 version so
maybe you are seeing this caveat;
Note
You cannot upgrade to firmware release 8.1(2) directly from firmware release 8.0(10) or an earlier release. You have to upgrade to firmware release 8.1(1) first, then upgrade from release 8.1(1) to release 8.1(2).
+5 to my friend Mark here as well for his good tips! I believe the 8-5-2 reference
is for models like the 7941, 7942 etc. though
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
10-01-2013 08:22 AM
I would bounce the TFTP server just in case. You can Find the default firmware under Device > Device Settings > Device Defaults. If you want to configure a phone to use a particular firmware, you can specify that on the phone configuration page - Phone load name. You have to enter the firmware load name without the extension of the file (.load).
Please rate helpful answers!
10-01-2013 08:26 AM
Hi David,
You are probably most correct in the need for an intermediate firmware
I might just try loading an older 7940 firmware like 8-0-1 & then use the
Phone Load Name setting on the Device config page in CUCM to update only
that phone.
Follow the steps in the attached doc to note the device defaults and load an individual
IP Phone.
Cheers!
Rob
- Bob Marley
10-02-2013 05:08 AM
Well, I tried manually setting up the phone and made some progress, however I went back to an older 8-0-1 and it just keeps reporting thats its downgrading now and continually loops trying to downgrade. Going to shoot for a higher one and see what happens.
10-02-2013 05:12 AM
Hi , if i remember rightly i think you need to take it to 8.5(2)
cheers
mark
10-02-2013 05:23 AM
Hi David,
Note
Cheers!
Rob
- Bob Marley
10-02-2013 06:18 AM
Thank you thank you......that worked with starting with 8.1.1, I thought I had to start lower. Can I give everyone 5 points???
10-02-2013 07:36 AM
Hi David,
You are most welcome my friend! Yes, "High Fives" for everyone
Cheers!
Rob
- Bob Marley
