Walkthrough Wednesdays
284
Geoffrey Seaman
Beginner
Random Dialing with 7970G IP phones
Hello all ,
I am having a issue where a person will pick up their handset or push their speakerphone button to make a call, and it dials either the last call or the last missed call. This has happened before after a CUCM upgrade, but we issued a reset and that solved it. Now After we issue the reset to the phone, it will start to occur again after maybe 1 hour on average. Not quite sure what is causing this and if there is any solution.
We are using CUCM System version: 8.5.1.12900-7
the 7970 phones are on Firmware SCCP70.9-3-1-1S
any help is appreciated. Thank you
3 REPLIES 3
paolo bevilacqua
Hall of Fame Master
There are other threads about tthis issue, use search function.
Leo Salcie Tejeda
Rising star
Hi Geoffrey,
To test if this is a hardware fault or software fault I would change the phone with another see if the same thing happens, if it doesn't then its the phone and if i does then it's the software running the phone.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
No hardware fault can cause random dialing.
As mentioned before, it's a cisco bug, check
https://supportforums.cisco.com/thread/2040209
Content for Community-Ad
Spotlight Awards 2021
