05-22-2015 12:04 PM - edited 03-17-2019 03:05 AM
Installing 5 new VG350,s, have 2 installed and randomly they have no dial-tone. I have practically read thru all the discussion on VG's and found this same problem using SCCP & in fact changed the In Hold-Queue to 300. I have 2 i had to put back on my old VGs, other times i can shut/no shut the voice port. Updated IOS-running newer code 15.2(4)M8. I currently use default on the voice-ports, thought i would try posting on here before opening a TAC case.
I have opened a TAC at the beginning, I had lots of NDT, i replaced the 72FXS module, rebooted the device. Any ideas?
Thx
Solved! Go to Solution.
10-16-2015 02:19 PM
Hmm,
We always use sccp for the analog vg'sif it has faxes on it we put these ports on SIP for the T.38 support.
The hold queue thing solved it for US.
Maybe worth a try to put it on sccp.
Paste the running config into a file in flash as a backup and enable sccp
05-05-2017 03:19 PM
I know this is old. Anyone try this?
config t
interface gig 0/0
hold-queue 300 in
Gi0/0 is my LAN interface/SCCP bound.
05-05-2017 11:27 PM
Nathan,
In my case it was because i had a loopback bound to sccp because we usd ospf for ha.
The hold-queue command needs then to be on both lan interfases to handle the burst of registraton messsges on top of all the other traffic.
Kind regards,
Peter
10-07-2019 06:44 AM
Did you have to reboot the VG for the change to take effect ?
08-31-2023 09:50 AM
I had the same issue with a VG420-144
interface GigabitEthernet0/0/0
ip address 10.x.x.x 255.255.255.0
negotiation auto
hold-queue 300 in
That's my current config and all seems to be working well.
11-02-2023 10:54 AM
I had the same problem with a VG420.
changed the In Hold-Queue to 300 worked.
