Re: CUCM 9.0.1 ldap case sensitivity bug fix
lukedp
Hello All,
I have been trying to find the download mentioned for the bug fix update for the below bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCub77825
I can not update to 9.1 at this point in time as other devices / surfaces have dependencies on 9.0.1. is this software available yet?
Jaime Valencia
You might want to open a tac and request 9.0(1.11003.1), all the other ones are 9.1 releases.
java
if this helps, please rate
Jaime Valencia
java
Thank you James,
Awaiting the response from TAC
