Re route incoming calls
tgut
Hi All
I got a problem trying to re route an incoming call
There is an E1, a PBX number, let's name it 1234, all incoming calls enter to a pilot nomber 3800 (operator)
recently was added a FXO line, let's name it 4567 and the calls enter to same extension, to this point everything goes fine
What i want is that all calls incoming from line 4567 be forwarded to an external number, let's name it 9999
Actually i am performing a call forwarding from extension 3835 to 9999, but i can't do it when the incoming call form 4567 be forwarded to the 3835, or even better, directly to 9999
Here the actual configuration
voice translation-rule 1
 rule 1 /1234/ /3800/
voice translation-profile XXXXX
translate called 1
voice-port 0/0/0:1
connection plar 3800
dial-peer voice 42 pots
translation-profile incoming XXXX
service aa1
shutdown
incoming called-number .
direct-inward-dial
port 0/0/0:1
forward-digits all
ephone-dn 8 octo-line
number 3835
label Ext 3835
description YYYYY
name YYYYY
call-forward all 9999
corlist incoming Usuarios
no huntstop
Thanks a lot in Advance!
Cheers!
Mikolaj Moryto
I am not sure if I correctly understand what you are trying to achieve, but why don't you try to set:
connection plar opx 9999
on your FXO interface?
Mikolaj
