Real-Time Monitoring Tool 8.91
CiscoDOJones
I am trying to get RTMT working on my laptop.    Using Windows 8.1 64-bit O/S.  Have downloaded RTMT 8.91 from my CUCM 8.6 system.
I install from Admin Command line path:>  CcmServRtmtPlugin.exe -I GUI
I select the path via the wizard and yeah all looks good.   At the end I get message saying that the installation of RTMT 8.91 is finished,but some errors occurred during the install.  Please see the installation log for details.
I go to the installation folder -->  log and the folder is Empty.
the main issue is there is no Desktop icon, nor can I find it from the Metro (or Apps) screen on Win8.1.    I then look in Explorer, but do not see any .exe files that might launch the Monitoring Tool.   All I have are .jar files.    which when clicked do not appear to do anything.   Apparently the Java Run-time Environment is installed as part of the RTMT install.
Can somebody help.   The Cisco doc "Chapter2:  Installing and configuring RTMT" gives no mention about this, and have not seen a similar issue raised in this community.
thanks in advance
Dave
A similar problem exists with RTMT v11.X when trying to install on a Windows2012 server.
The installer proposes as default directory /opt/Cisco/... and reports some errors. After installing the JRE folder is empty and jrtmt.exe is missing.
To solve it: Right click the installation file, select Properties and adjust Compatibility to Windows 8.
Geert.
CiscoDOJones
Got it sorted.......Google is Awesome !!!!   :)
FYI.....once the file has been downloaded from CUCM Plugins.   Locate the installation file, Right click, Properties, Compatibility and enable compatability with Windows 7.
Did the trick for me  :)
Dave
Geert.
Wilson Samuel
Level 7
Level 7
Almost all of the Cisco tools use Java / JRE (or whatever they are called) and I have faced this situation countless times.
I would request you to go to java.com, check if you have the latest Java/JRE (they have a tool for that) and most importantly , uninstall any older and incompatible versions of the Java / JRE
Once Java is fixed, I am sure the RTMT will work.
Let us know, how it goes.
