07-20-2015 08:59 PM - edited 03-17-2019 03:42 AM
hi Team,
we are using 7821 series phones, and on the phone there is a New Softkey "Recents" this key doesn't appear in Softkey configurations layout so can't be removed. While doing some search found that it is a Bug.
https://tools.cisco.com/quickview/bug/CSCuu74767
My question is:
If I press "Recents" Softkey it shows the previous dialed number (like Call History) however the strange party is if I pickup the phone while on Recents screen, it automatically dials the number. Has anyone encountered this before, Is there a way we can stop it to auto dial ?
Appreciate your inputs .
Anil Sharma.
07-20-2015 09:34 PM
Is this for CME or CUCM?
07-20-2015 11:01 PM
Sorry, I should have mentioned its CUCM 10.5.2
07-20-2015 11:18 PM
I did a research since this is new to me and concluded that it can't be disabled as this is builtin feature in the phone code.
Sorry for this.
Why don't you try downgrading the phone firmware to resolve the bug.
07-20-2015 11:22 PM
Alright Mohammed, I will pass this on to my customer.
I understand Cisco will be working on Bug to get an option of add/remove "Recents" from Soft key configuration layout.
However will they be also working on stop auto dialing , do you know ?
Anil Sharma
07-20-2015 11:30 PM
Not heard about disabling it.
07-23-2015 05:17 AM
You are right Mohammed, Recents is added in latest firmwares & most of the phones are already shipped with latest firmware so can't do anything with those. (i think)
Found one phone with little older firmware which didn't have this key. But for consistency I have to upgrade that one too.
07-23-2015 06:41 AM
You can downgrade the firmware of the phone. Download the previous version e.g. 10.2(2). Upload the image to your CUCM (From OS administration). Change device defaults in CUCM administration to the name of the downgraded image and reset your 7821 phones.
Just make sure that you verify the downgrade/upgrade paths using firmware release notes.
It is not mandatory to stay on the latest firmware neither recommended.
*** Please rate useful posts
07-28-2015 01:29 AM
10-11-2016 02:25 AM
Anyone have a solution to remove this softkey "Details" ??
Matthieu
03-28-2017 01:49 AM
Found by changing services provisioning setting within the device page fixes this, device was a 7841.
04-07-2017 11:11 AM
Hi Kyle, is this what you changed ?
10-06-2021 01:45 AM
By default it's enabled in the phone settings, can be disabled by going to the phone itself, look for Recents Softkey and disable it
11-23-2016 01:53 PM
Hi Anil,
Did you ever find out if there is a way to stop the auto dialing when a number is highlighted in "Recents" tab
07-20-2015 11:24 PM
regarding downgrading the firmware I believe these phones are coming with updated Firmware, However I will cross verify.
