10-27-2015 01:21 PM - edited 03-17-2019 04:43 AM
It seems that we are hitting the bug CSCuj64211.
The gateway IOS is 15.2(4)M9 and the DSP is 32.1.8
I have the impression that our IOS version has this defect fixed but I am not sure (we are getting the same error and we have to reload the gateway to fix it)
Can somebody verify that this version has the fix and if not to which version we need to go to ?
Thx,
Christos
10-27-2015 01:42 PM
The bug which you have mentioned affected for DSP version 35.1(02)DSP . as always recommended to sit on the latest version prior checking the Release notes .
10-27-2015 01:53 PM
Hi Naveen,
Thanks for the answer. Does this mean that we are not affected by this bug since our DSP is different ?
10-27-2015 06:10 PM
are you facing the same behaviour in enviornment or just suspected issue around?
Br,
nadeem
10-28-2015 12:11 AM
Yes. I get the same error as the bug and we have to reload the gateway for the calls to go through
10-30-2015 10:25 AM
Can somebody confirm to me which IOS version has the fix for the above bug ?
10-30-2015 11:42 AM
I dont know about this specific bug, but lately I have implemented many 15.4.3M<latest> and have not run into any major bugs, for both CUBEs and TDB GWs.
