recording profile in CUCM
karthik ratna
hi all,
please help me on recording profile
we have one recording profile which is pointing to cybertech
when i have enabled on profile of user ( active recording ), so calls will be recorded on cybertech ( calling number , called number , timing ) or we need to add same user in cybertech also
where i can get good docs on cybertech configuration ?
kindly keep me right direction plz
Thanks in advance
Karthik
Joseph Martini
This depends on the cybertech system.  If they use JTAPI to connect to CTIManager for call recording information then you would have to create a user on CUCM as well as the matching username/password on the cybertech side.  If cybertech does not use an JTAPI/CTI integration with CUCM, you do not need any user configured in either CUCM or cybertech.
Joseph Martini
Hi ,
Thanks for your response
Kindly suggest the good document for cybertech , i was new to this
Karthik
