08-01-2011 01:31 AM - edited 03-16-2019 06:13 AM
Hi everybody!
My question is, a I have a mockup in vmware with CUCM 7 and CUC 7, the problem is that I have forgotten my Unity Connection password, and is the same in the web administration and in vmware´s, so, anybody knows any trick to get out user name and password again??
thanks and regards!
08-01-2011 02:39 AM
This should work for cucm and ucxn either.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_0_1/cucos/iptpch2.html#wp1044244
Steffen
08-01-2011 02:48 AM
Thanks for your reply,
I tryed that before but I have a problem with step 5:
Step 5 Insert a valid CD or DVD into the disk drive.
I tryed with several CDs and nothing....... any idea what is the problem here?
thanks.
08-01-2011 02:54 AM
You run the system in vmware, correct ?
Maybe a topic with the drive association in VMware?
Unfortunately I do not have another idea...
Steffen
08-01-2011 03:00 AM
That´s correct, i run system in vmware.
I checked drive association and CDs and nothing....
ok, I will trying it, when I get it I will show u, ....thanks !
08-01-2011 03:45 AM
ok I get it!!!
In cisco web page is not correctly explained....
Step 1 Log in to the system with the following username and password:
•Username: pwrecovery
•Password: pwreset
The Welcome to platform password reset window displays.
Step 2 Press any key to continue.
Step 3 If you have a CD or DVD in the disk drive, remove it now.
Step 4 Press any key to continue.
The system tests to ensure that you have removed the CD or DVD from the disk drive.
Step 5 Insert a valid CD or DVD into the disk drive. <---- This must be the recovery DVD from CUC
After it follow step to change password.
regards!!
