01-21-2016 06:21 AM - edited 03-17-2019 05:35 AM
We are using a CME set up where IP Phone model 6961..9951..3905 ...are in use but from any of the phone ..not able to redial on received mobile or outside call..
when i called from my mobile number to IP Phone DID..it display like 9819640XXX...but when I press redial key to call back the 9819640XXX it not works ...
01-21-2016 09:31 AM
What is not working? Are you getting busy tone or redial key not responding.
01-21-2016 08:17 PM
Hello Mohammaed,
Yes ia m getting busy tone
01-21-2016 10:51 AM
You mean when you can phone directory "received call" and select the number and hitting dial button ?
what happen when dial this number " 9819640XXX" do you get re-order tone? do you have dial-peer for same destination configure? can you quickly grab some debug to check why its not working.
Debug voice ccapi inout
debug isdn q931 if you have PRI
01-21-2016 08:18 PM
Hello NAdeem getting busy tone..below is the dial-peer for this .
dial-peer voice 200 pots
corlist outgoing OGLOCAL
description "Outgoing Local Landline"
translation-profile outgoing 12
preference 2
destination-pattern 00[2-2][0-2]........
direct-inward-dial
port 0/0/0:15
forward-digits 12
no sip-register
dial-peer voice 201 pots
description "Outgoing Local Mobile"
translation-profile outgoing 10
preference 2
destination-pattern 0[7-9].........
direct-inward-dial
port 0/0/0:15
forward-digits 11
no sip-register
01-21-2016 08:51 PM
Since you are dialing 10 digit mobile number starts with 9 and it is not matching with any dial peer. Either you need to manipulate the CLI during incoming call so that it can match with configured destination-patterns (while making outbound call) OR configure additional dial peers to take care of respective outbound calls if you don't want to change the CLI during incoming call.
- Vivek
01-22-2016 04:42 AM
As stated, you dialpeers aren't having 9T destination patterns which is dropping the call. The simplest approach is to have additional dialpeer with 9T as below.
dial-peer voice 880 pots
description "Redialed Calls"
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
01-24-2016 03:44 AM
Hello Mohammed,
Our access code to dial any outside number is 0...
so can i cehck with the destination-pattern 0T
01-24-2016 03:57 AM
Hi Vijay,
Can you please activate a debug isdn q931 and debug voip dialpeer inout and call from outside to your extension?
Can you also please specify if you have this issue on ip phones locally registered on CME or on IP Phones registered on Cucm cluster in Germany?
Carlo
01-24-2016 04:00 AM
Hello Carlo,
Facing problem ip phones locally registered ....will share the debug ASAP..
01-24-2016 10:39 PM
Hello Please find the the debug..here from IP Phone try to redial 8879645246...
where found the error "No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)"
Where i created the dial-peer.
dial-peer voice 110 pots
translation-profile outgoing 23
direct-inward-dial
port 0/0/0:15
dial-peer voice 111 pots
direct-inward-dial
port 0/0/0:15
dial-peer voice 112 pots
destination-pattern 0.T
direct-inward-dial
port 0/0/0:15
dial-peer voice 113 pots
destination-pattern 9.T
direct-inward-dial
port 0/0/0:15
01-24-2016 11:41 PM
What is the number which you see on your missed calls logs and trying to redial?
01-26-2016 08:51 PM
voice translation-rule 100
rule 1 /^9\(.*\)/ /09\1/
rule 2 /^8\(.*\)/ /08\1/
rule 3 /62\(.*\)/ /002\1/
rule 4 /\(.*\)/ /000\1/ type international international
rule 5 /\(.*\)/ /00\1/ type national national
voice translation-profile Inbound
translate calling 100
voice-port 0/0/0:15
lpcor incoming pstn_group_LOCAL
lpcor outgoing pstn_group_LOCAL
translation-profile incoming Inbound
description e1
Issue was resolve we created the new voice translation-rule & applied as incoming on the voice port
thanks for support ..
01-24-2016 08:35 AM
01-26-2016 08:50 PM
voice-port 0/0/0:15
description e1
