Redirected call Calling Party Number (fixed fall forward)
Alex-Pr
Hey there,  Looking for some assistance with CUCM.
I am trying to make the Calling ID for redirected calls show the 10 digital local number of the IP sets
In the gateway (setup for MGCP) under "Call Routing Information - Outbound Calls"
If I set "Calling Party Selection" to "first redirect number" or "first redirect number (external)" it uses the 4 digit extension of the set as the Calling Line ID.
How do I get it to show the full 10 digit DID?
When looking at the logs I see
Calling Party Number i = 0x2183, '4444'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '4165551234'
Plan:Unknown, Type:Unknown
Redirecting Number i = 0x00008F, '4444'
What I want is for the Calling Party number to show as '4166784444'
Thanks for your help
b.winter
have you tried to using calling transformation patterns (in partition / CSS) and assign it on the MGCP-endpoint under "Redirecting Party Transformation CSS"?
So that the 4-digit numbers get prefixed.
The "Calling Party Selection" only specifies, which field should be used for the calling number (not the redirecting). I would leave this set to "Originator".
Best regards,
Björn
