Reduce Dial-Peer Timeout preference on POTS
Hi all,
I have a Voice Gateway h323, and it has 2 E1 VWIC Cards Conected to 2 Different PSTN Carriers, I've experiencing intermitences on the CO Company Service and I decide to Add for each dial-peer, a copy with a preference of 2 for backup,
The problem here is that it take about 10 seconds to jump to the back up dial-peer.
Example:
dial-peer voice 124 pots
preference 1
destination-pattern 906.
port 0/1/1:0
prefix 06
no register e164
dial-peer voice 125 pots
preference 2
port 0/1/0:0
prefix 06
no register e164
I know there is a h225 command for Voice Dial-peers, but that can´t be applied to Pots dial-peer.
voice class h323 1
h225 tcp timeout establish 3
How can I reduce the timeout establis for pots dial-peers?
Reggards.
acampbell
Try adding
dial-peer outbound status-check pots
This will stop the gateway looking at the outgoing dial peer if the voice port is down
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Try adding
Alex.
Well I used this command, but I have not way to check it, so thanks for the help and there are your 5 stars.
Reggards,
Juan
Thanks for the rating
Have a we look at this link - a good explanation
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_d1_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1459139
Alex.
