04-08-2013 09:40 PM - edited 03-16-2019 04:40 PM
I need to configure Redundancy Combined with Centrelise Call Processing in CUCM.
I need to configure 1:1 Redundacy.
we have total 5 Servers (7845). and need to Desing 1 Pub. and 1 group of Sub(2 Servers) and 2 group of sub(2 Servers).
kinldy guide what are configration steps I need to follow.
thanks
04-08-2013 09:44 PM
HI
You have to creat CUCM Groups and keep the Subscribers in those groups. Assign those group to Device pool.
Divide the Ip phone based on your requirement and assign that device pool.
How to create the Group is showsn as follows
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmcfg/b02cmgrp.pdf
Ronak Patel
Rate all helpful post by clicking stars below the answer.
04-08-2013 09:49 PM
thanks for reply.
as I said we have 5 servers. when we creat the group only 4 servers allow.
I need to creare 2 sub bundle of 4 servers.
what are the steps, ?
should I have to change any confirgartion in sub also?
please guide
04-08-2013 09:54 PM
I am not clear on your query But You can add up to 3 call processing CUCM in one group.
Ronak Patel
04-08-2013 10:21 PM
Just create as many CUCM groups as you like, with the mixture of those 4 SUBs as required for redundancy, and assign those to the device pools for the phones.
That's all you need to do.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
04-08-2013 10:27 PM
yes one qustions is clear.
Now tell me, in each group we need to add Pub and require SUB. correct..?
and add these group in Device pool ?
Jayesh
04-08-2013 10:30 PM
No, you usually do not add the PUB, if you want 1:1. then just use the SUBs.
Yes, you use the CUCM groups in the device pools.
java
