Redundancy for my CUCM and Unity connection using two core switches
abarakat81
Hi guys,
if anyone knows how to connect my call manager (publisher) to two core switches 6509 to be able to have redundancy so if one of my switches goes off the secnd switch will be able to keep the cucm up and running. I want to be be able to have redundancy all over using these twp switches for my CUCM and Unity connection.
Thanks a lot..
Chris Deren
What type of hardware are you using for your CUCM? Is it physical MCS server or virtualized server?
If physical you can use NIC teaming on the server, if virtulized then you can assign multiple NICs to the vSwitch.
Chris
Actually we are using physical server , so it is a NIC teaming. When you said on the server, did you mean on the CUCM CLI or the physical server itself and how we do that ?
See this:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_3/cli_ref_713.html#wp40017
should still be the same on any Appliance version of CUCM/UCON.
HTH, please rate all useful posts!
Chris
