06-12-2012 01:50 AM - edited 03-16-2019 11:37 AM
Hello Geeks
I have a requirement to connect two offices in same company with 60 users each through a t1 line to support internet access /file server and VOIP. network should be redundant (24*7 ) operations similar to a call center . should have VPN access and VLANS. prefer cisco devices
If t1 line or a router fails there should be automatic failover method
Cheers
06-12-2012 02:10 AM
I think using PPP multilink can help you in t1 failure. And you can use CME redundancy in case of router fail.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
06-12-2012 03:18 AM
Hi patel
Thanx
Can you breifly explain cisco devices need to install in two offices ? what are the WAN connections need for redundancy in addition to T1 line? ?( do i need hsrp/vrrp) what is the best cisco device including VPN and VOIP ? what about firewall and VLAN ?
Sorry that my VOIP experiance is little.
Thank you very much
06-12-2012 03:29 AM
You can use two two Cisco ISR router at each site, they are good for VOIP design. I think when you terminate your WAN on both the routers in the site, The WAn redundany will be taken care by routing protocol. And voip redundancy will be taken care by CME configuration.
Ronak patel
Rate all helpful posts by clicking stars below the answer.
06-12-2012 03:52 AM
ok thanx since this a point to point connection static routing can be used i suupoose ? what about the firewall and VLAN setup ? Also if this T1 line fails what is the back up connection ? will this create a single point of failure? Thanx
