09-02-2015 08:09 PM - edited 03-17-2019 04:12 AM
Hi all,
Looking for your help!
We are using CME v 8.6 and I have a to scenario for call forwarding :
There are two phones, one is for manager (Phone A) and another is for receptionist (Phone B).
Requirement is that if Phone A does not pick up the call or it's busy in that case call should be forwarded receptionist phone i.e. Phone B and if receptionist also unavailable then call should go to voicemail of Phone A.
In current Phone A configuration:
ephone-dn 32 dual-line
number 12345678
description XYZ
name XYZ
call-forward busy 87654321 (forwarded to VM)
call-forward noan 87654321 timeout 10 (forwarded to VM)
Thanks !
09-02-2015 08:25 PM
Hi Abhishek,
You can check the following setting on CUE:
"Mailbox selection (OCN or LRD)"
This configurable option specifies the mailbox to be used in case of call forward.
Mailbox selection: Mailbox in which an incoming voice message is stored. The options are original called number (OCN) or the last redirected number (LRD). LRD is the default option. In your case it will be OCN.
Check out Page 88 of this doc -
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/cliadmin/cuecli23.pdf
Manish
- Do rate helpful posts -
09-02-2015 08:55 PM
Hello Manish,
Thanks for your reply !
As I checked, it's set as "Last Redirecting Party", i.e. LRD
Please let me know how to configure phone A as per the requirement as mentioned in my first post ?
Thanks!
