260
Highlighted
Beginner
Region / Location BW issue Video Endpoints
Hello All,
I have 6 Video Units:
Cisco TelePresence Profile 52 Dual (C60)
Cisco TelePresence SX20
Cisco TelePresence SX10
Cisco Spark Room 55
All are in the same region also in the same location,  as per customer advise they need to set 2M BW for each unit and also have a limitation on the location BW to be up to 14M which is (2*M*6Units) +2M reserve =14M
Location Immserve BW (14M)
Location Video BW (14)
When we do the previous scenario only 3 Endpoints work V/A and the other 3 work Voice only
but when we set the Location BW
Location Immserve BW (unlimited)
Location Video BW (unlimited)
Everythings work fine
Region: Factory Default low loss 256 kbps (L16, AAC-LD) 32000 kbps 2147483647 kbps
Default Intraregion Max Video Call Bit Rate (Includes Audio) Required Field (384)
Default Intraregion Max Immersive Video Call Bit Rate (Includes Audio) Required Field ( 2M)
I need to know what is the right setting so they all can work fine with limited BW
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: Region / Location BW issue Video Endpoints
Hello Anthony,
Appreciate your help.
Use Video BandwidthPool for Immersive Video Calls set to (True)
4 REPLIES 4
Highlighted
VIP Collaborator
Please try below settings:
Under Region Section:
Maximum Session Bit Rate for Video Calls: 2000 kbps
Maximum Session Bit Rate for Immersive Video Calls: 2000 kbps
Under Locations Section:
Remember to set MaxTransmitCallRate and DefaultCall Rate on each video endpoint to 2000. For this, you need to login to each video endpoint.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Highlighted
Beginner
Hello Vaijanath,
That's the case when I do the above configuration you advised me with the issue happens
Thanks for your help.
Highlighted
VIP Mentor
What is your CallManager Service Parameter for Use Video BandwidthPool for Immersive Video Calls set to?
Anthony Holloway
Highlighted
Beginner
Hello Anthony,
Content for Community-Ad
Cisco COVID-19 Survey
