09-16-2014 04:54 AM - edited 03-17-2019 12:10 AM
Hi all,
i don't know if it is so obvious but i really can't find a solution!
And i can't find enough discussions so that means that i am completely wrong or nobody has tried it before.
I can see that my CUCM 9.1 offers 887VA-V subscription as SCCP gateway subscription.
Also, it offers a module VWIC-SLOT and then ports 0/0/0 through 0/0/3.
Therefore, if i enter the last 10digits of my 887s SCCP source interface mac-address, it creates a Device: AN1234567890000 through AN1234567890003
BUT,
my 887's config, which has fxs port 3 to 6 produces devices with names:
AN1234567890080 to AN1234567890083!!
What am i doing wrong.
Please advise:
IOS:c880voice-universalk9-mz.151-4.M4.bin
CUCM: 9.1.2(X)
Solved! Go to Solution.
09-18-2014 01:44 AM
I was aware of the same but I though of sharing so that if u could get some clue.
If the problem is there, please open the case and share findings.
regds,
aman
09-16-2014 06:14 AM
Hi.
Can you please share the output of a show voice port summary?
Carlo
09-16-2014 08:01 AM
Hi Carlo,
here is the output:
vgw-r1#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
1 1 bri-voice up dorm none none y
1 2 bri-voice up dorm none none y
2 1 bri-voice up dorm none none y
2 2 bri-voice up dorm none none y
3 -- fxs-ls up dorm on-hook idle y
4 -- fxs-ls up dorm on-hook idle y
5 -- fxs-ls up dorm on-hook idle y
6 -- fxs-ls up dorm on-hook idle y
50/0/1 1 efxs up up on-hook idle y
50/0/2 1 efxs up up on-hook idle y
50/0/3 1 efxs up up on-hook idle y
50/0/4 1 efxs up up on-hook idle y
50/0/5 1 efxs up up on-hook idle y
50/0/6 1 efxs up up on-hook idle y
50/0/7 1 efxs up up on-hook idle y
50/0/8 1 efxs up up on-hook idle y
50/0/9 1 efxs up up on-hook idle y
50/0/10 1 efxs up up on-hook idle y
PWR FAILOVER PORT PSTN FAILOVER PORT
09-16-2014 09:12 AM
Not sure, if this biug is somewhat related to your issue.
09-16-2014 11:38 PM
Hi Aman,
this bug refers to MGCP configuration.
For SCCP, i choose the same about subunit but it CUCM creates 4 ports named:
0/0/0, 0/0/01, 0/0/2 and 0/0/3.
This means that the last 3 digits of the SCCP device that CUCM creates (and cannot be altered) are 000 to 003.
But, as i told you in my previous email, port 3 in 887VA-V is created with 080 suffix (and port with 083 suffix)!
vgw-r1#show stcapp device summary
Total Devices: 2
Total Calls in Progress: 0
Total Call Legs in Use: 0
Port Device Device Call Dev Directory Dev
Identifier Name State State Type Number Cntl
0/1/0 AN542DEA5DF6080 OOS UNREGISTERED ALG UNKN
0/1/3 AN542DEA5DF6083 OOS UNREGISTERED ALG UNKN
IN OUT
vgw-r1#
Cheers,
Anthony
09-18-2014 01:44 AM
regds,
aman
09-23-2014 01:36 AM
thanks for updates.
can u please share output of command show stcapp device summary and snapdhot from CUCM?
regds,
aman
09-23-2014 01:17 AM
Hi all,
it is a known bug with id CSCul59124 similar to the one regarding MGCP registration.
DO NOT add 887VA-V as 887VA-V but as 881/886/887.
Then, add FXS in subunit 1 and not 0.
This action, creates an analog device with suffix in the range 080-083.
Anthony
