11-03-2015 09:44 AM - edited 03-17-2019 04:47 AM
Hi gyus
I have a CUCME 10.0 and i trying to resgister a 8945 phone, the cucme already have a phone 8941 registered and in operation. But when i try to make upgrade the firmware to the phone i have the follow log.
Nov 3 17:46:59.437: TFTP: Looking for CTLSEP204C9E6DFDDF.tlv
Nov 3 17:46:59.477: TFTP: Looking for ITLSEP204C9E6DFDDF.tlv
Nov 3 17:46:59.517: TFTP: Looking for ITLFile.tlv
Nov 3 17:46:59.557: TFTP: Looking for SEP204C9E6DFDDF.cnf.xml
Nov 3 17:46:59.557: TFTP: Opened system:/its/vrf1/SEP204C9E6DFDDF.cnf.xml, fd 4, size 1759 for process 321
Nov 3 17:46:59.561: TFTP: Finished system:/its/vrf1/SEP204C9E6DFDDF.cnf.xml, time 00:00:00 for process 321
Nov 3 17:47:02.953: TFTP: Looking for SCCP894x.9-2-2-0.loads
Nov 3 17:47:02.953: TFTP: Opened flash0:SCCP894x.9-2-2-0.loads, fd 4, size 641 for process 321
Nov 3 17:47:02.957: TFTP: Finished flash0:SCCP894x.9-2-2-0.loads, time 00:00:00 for process 321
Nov 3 17:47:14.369: TFTP: Looking for SCCP894x.9-2-2-0.bin1.sgn
Nov 3 17:47:14.373: TFTP: Opened flash0:SCCP894x.9-2-2-0.bin1.sgn, fd 4, size 3145116 for process 321
Nov 3 17:47:22.861: TFTP: Finished flash0:SCCP894x.9-2-2-0.bin1.sgn, time 00:00:08 for process 321
and the phone never go for the next files.
Attach my config.
tftp-server flash:SCCP894x.9-2-2-0.loads
tftp-server flash:BOOT894x.0-0-0-9.bin.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin1.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin2.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin3.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin4.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin5.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin6.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin7.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin8.sgn
telephony-service
sdspfarm units 2
sdspfarm tag 1 conference
sdspfarm tag 2 transcode
conference hardware
video
maximum bit-rate 512
no auto-reg-ephone
max-ephones 165
max-dn 500
ip source-address 10.56.X.X port 2000
service phone videoCapability 1
url directories http://10.56.X.X/localdirectory
url services http://10.56.X.X/voiceview/common/login.do
url authentication http://10.56.X.X/CCMCIP/authenticate.asp
cnf-file perphone
user-locale ES
network-locale ES
load 7937 apps37sccp.1-4-5-7
load 6921 SCCP69xx.9-4-1-3
load 6941 SCCP69xx.9-4-1-3
load 8941 SCCP894x.9-2-2-0
load 8945 SCCP894x.9-2-2-0
olsontimezone America/XXXX version 2010o
time-zone 11
Any idea?
11-03-2015 11:29 PM
Can you also let us know what is the current firmware version on the phone and whether its Release 9.1(2)SR1 and later or not because any firmware version below this will have the below mentioned issue:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8941_8945/firmware/9_2_2/english/release/notes/8941_8945_922.html#wp194878
Also what exactly happens on the phone when you try to upgrade.
Rajan
11-04-2015 06:27 AM
Hi Rajan
Thanks for your answer, i can't see the phone the device is in another country, the phone remain in state upgrade and then phone reboot.
In the log the CUCME i see the phone trying to register several times but always the upgrade fail.
Regards.
11-05-2015 12:33 AM
Can you try to use the below command and see whether you are able to see the load for this phone.
show ephone phone-load
