register CME to SIP trunk by TCP 5060
Alex55555
Beginner
Beginner
My ITSP ask me to register CME to his SIP trunk not by usial UDP 5060 port but using TCP 5060.
How to do it?
CME version 12.0 on 2911 router IOS 15.7(3)M5
Rajan
Collaborator
Collaborator
Hi Alex,
You have to use the below in the config to register using TCP:
sip-ua
registrar XXXX expires XXX tcp auth-realm XXXX
no transport udp
Also in all the dial-peers pointing to the SIP trunk, you can use the below command:
dial-peer voice X voip
session transport tcp
Rajan
Please rate all useful posts by clicking the star below and mark solutions as accepted wherever applicable
Alex55555
Beginner
Beginner
ITSP check his config and solve my problem without doing TCP registration
Recognize Your Peers
