03-27-2014 02:43 AM - edited 03-16-2019 10:16 PM
Howo to have dual line Cisco Phone to be registered each line per different server?
Thanks.
03-27-2014 06:39 AM
Each device registers to single server at a time with all extensions, not sure why you would want each line registered to different servers. Can you elaborate?
Chris
03-29-2014 07:34 AM
03-30-2014 09:29 PM
Choose to which cluster you will register the phone, and both lines, and then emulate that behavior via call routing (CSS/partitions/RPs)
03-30-2014 02:49 AM
Hello Eugen,
Is this the same cluster?
if you want Line two to go through PSTN2, simply use CSS points to RL of PSTN2
Mohamed Helmy.
03-31-2014 01:36 AM
Hi Eugen,
You can not register the lines of the phone . Phone registers to the server. If you need the lines of the phone to use different gateway than you can use partiton/CSS . you need to create an ICT or SIP trunk between your two clusters and than create a route pattern, such that it will send the call through the ICT and than other server can route it through its gateway.
NOTE: for this kind of setup you would be using your WAN bandwidth so configure it to use G729
