11-22-2012 06:55 PM - edited 03-16-2019 02:20 PM
Hi everybody
Please consider the following:
Iphone1------------CME/tftp
CME router has following config:
telephony-service
load 7960-7940 P00308000500
max-ephones 4
max-dn 4
ip source-address 201.201.201.1 port 2000
cnf-file location flash:
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1
number 20001
ephone-dn 2
number 20002
ephone 1
mac-address 0006.537B.84EF
button 1:1
ephone 2
mac-address 0006.28F0.F7E7
button 1:2
The cisco ipphone1 i(201.201.201.11) issending CME( 201.201.201.1) following register message.
No. Time Source Destination Protocol Length Info
405 107.462363 201.201.201.11 201.201.201.1 SKINNY 130 RegisterMessage
Frame 405: 130 bytes on wire (1040 bits), 130 bytes captured (1040 bits)
Ethernet II, Src: Cisco_7b:84:ef (00:06:53:7b:84:ef), Dst: Cisco_37:8a:c0 (00:12:d9:37:8a:c0)
Internet Protocol Version 4, Src: 201.201.201.11 (201.201.201.11), Dst: 201.201.201.1 (201.201.201.1)
Transmission Control Protocol, Src Port: 49824 (49824), Dst Port: cisco-sccp (2000), Seq: 105, Ack: 1, Len: 76
Skinny Client Control Protocol
Data length: 68
Header version: Basic (0x00000000)
Message ID: RegisterMessage (0x00000001)
Device name: SEP0006537B84EF
Station user ID: 0
Station instance: 1
IP address: 201.201.201.11 (201.201.201.11)
Device type: TelecasterBus (8)
Max streams: 0
I just want to know if Station instance is 1 because of these commands :
ephone 1
button 1:1
ephone-dn 1
number 20001
thanks and havea great day.
Solved! Go to Solution.
11-23-2012 12:07 AM
Hi Sarah,
This doesnt appear to have anything to do with the ephone or ephone-dn config. I took a pcap for a CIPC and I see
"StationInstance: 0" whereas the ephone tag for this phone is 3. It could possibly be associated with the phone type/model or the skinny load it is running, since this is a register message coming from the endpoint.
http://www.wireshark.org/docs/dfref/s/skinny.html
Field name | Type | Description | Versions |
skinny.stationInstance | Unsigned integer, 4 bytes | Station instance | 1.0.0 to 1.8.3 |
There isnt much documentation on it apparently.
HTH.
Harmit.
11-23-2012 12:07 AM
Hi Sarah,
HTH.
Harmit.
