06-24-2012 06:27 PM - edited 03-16-2019 11:49 AM
Guys
Is it possible for an IP phone like the 9971 to register to both a SIP gateway and SCCP or is the phone only capable of running one kind of firmware?
If so, can I connect to two different SIP proxies at once?
06-24-2012 08:33 PM
99XX phones supports only SIP protocol and SCCP is not suppoted by them. Belw data sheet shows the supported protocol
Also when you try to download firmware for this phone you wil lonly find SIP firmware as it nly support SIP protocl.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
06-24-2012 09:08 PM
And just to add, any of the other models in which you get to choose betwen SIP or SCCP, it's one or the other, you cannot have both at the same time on the same phone. Either it's a SCCP phone or it's a SIP phone.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
