Showing results forĀ
Search instead forĀ
Did you mean:Ā
Registering 7937 phone on UC520
christianojum
I want to register a 7937 conference phone on  uc520 and i noticed that the phone fimware is not included. I also read some documents that says that 7937 is not supported on uc500.
The application is Version 4.2(0). The ios is Version uc500-advipservicesk9-mz.124-11.XW7.
I will appreciat a guide on how i can get this done.
Regards.
Rob Huffman
Hi Christian,
The 7937 is supported with newer IOS's
From Steve @ Cisco
https://supportforums.cisco.com/message/3083146#3083146
https://supportforums.cisco.com/docs/DOC-9827
Cheers!
Rob
Many thanks,
My flash is 128MB,
Is there any of the UC520 Software Pack within 128MB that can support 7937 Phone. I will apprecial if you also provide me with the compatible CCA version (cisco Configuration assistant).
One more question, must I use configuration assistant to configure UC520.? Cant I configure it with CLI?
Chris.
You can configure UC520 with CLI indeed because this is still IOS based and for telephony it uses CUCME.
Regards.
Alain.
