10-27-2014 01:40 AM - edited 03-17-2019 12:41 AM
Hi all,
i have Cisco SIP IP Phone 7821. I have trouble to make it registered with my CME 10.5. i have trying fast-track configuration and many advice from the other discussion, but still no luck at all. Hereby my CME configuration :
Version 15.4(3)M
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
bind control source-interface Loopback10
bind media source-interface Loopback10
registrar server
voice register global
mode cme
source-address x.x.x.x port 5060
max-dn 400
max-pool 50
load 7821 sip78xx.10-2-1-12.loads
timezone 41
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile
network-locale GB
ntp-server x.x.x.x mode directedbroadcast
voice register dn 1
number 1010
name 7821
label NewSIP1
mwi
voice register pool 1
busy-trigger-per-button 2
id mac xxxx.xxxx.xxxx
type 7821
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
tftp-server flash:kern78xx.10-2-1-12.sbn
tftp-server flash:rootfs78xx.10-2-1-12.sbn
tftp-server flash:sboot78xx.10-2-1-12.sbn
tftp-server flash:sip78xx.10-2-1-12.loads
Need your advice,
thanks.
11-05-2014 01:51 PM
If you are still having this problem, you need to add the following on your configuration:
voice service voip
sip
registrar server expires max 600 min 60
Let me know if that works...it did for me. After debugging registration, the phone was looking to register to the server.
11-13-2014 05:12 AM
Hey;
try this and please let me know if it fixed;
Voice register pool 1
type 7821
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
session-transport tcp
and go to "voice register global"
create profile
if problem still active please attach "debug tftp events" and status messages from an ip phone maybe you can take a pic of screen
Good day
04-26-2015 10:59 AM
Hi adnanramadhan12 !!!
My name is Enrique Villasana and I have similar problem right now...
I have Ip phones 7821/7841 and CME 10.5 IOS:154-3.M2.
Here you have my current configuration:
voice service voip
ip address trusted list
ipv4 10.2.50.0 255.255.255.0
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call start slow
sip
bind control source-interface GigabitEthernet0/0.3
bind media source-interface GigabitEthernet0/0.3
description Voice VLAN
encapsulation dot1Q 3
ip address 10.2.50.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip traffic-export apply TAC size 10000000
mode cme
source-address 10.2.50.254 port 5060
max-dn 180
max-pool 42
load 7821 sip78xx.10-1-1SR1-4
load 7841 sip78xx.10-1-1SR1-4
authenticate register
timezone 14
tftp-path flash:
create profile sync 0008536074803216
voice register dn 1
number 235
pickup-call any-group
name Reception Reception
label Reception Reception
busy-trigger-per-button 1
id mac aaaa.bbbb.cccc
type 7841
number 1 dn 1
template 1
dtmf-relay rtp-nte
username cisco password cisco
description Reception
codec g711ulaw
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
tftp-server flash:sip78xx.10-1-1SR1-4.loads
tftp-server flash:kern78xx.10-1-1SR1-4.sbn
Could you solved your problem?? If so , could you please tell what I am missing or misconfiguring on my current configuration??
I really appreciate your help !!
Enrirque Villasana
08-18-2015 01:29 PM
Hello Adnan,
I am facing same issue in CME 10.0.
How did you ended up with your problem ?
08-18-2015 02:51 PM
Hi Ilana!!
As I explained on another similar case... after one week testing (and fighting) with Cisco TAC, they accepted my RMA requirement of the SPIAD Router.
Once I received and installed the replacement router, all phones registered !!!! Including a new CP-8831 !!
If you have a SPIAD Router, with similar strange behavior i really recommend you to require a RMA.
I HTH
Enrique
