01-05-2016 03:50 AM - edited 03-17-2019 05:24 AM
Hi all!
I have a VG202XM unable to register with a CM 10.x, is stuck in Registering with CM
I have double check the name in both sides and it match, please see below the config, if anybody find any issue or something to change please say me, thanks
sh run
Building configuration...
Current configuration : 2009 bytes
! Last configuration change at 17:16:33 UTC Mon Mar 4 2002
version 15.3
no service pad
hostname CUST6-VG202-MGCP
boot-start-marker
boot-end-marker
aqm-register-fnf
logging buffered 4096
no logging monitor
no aaa new-model
ip cef
no ipv6 cef
voice-card 0
archive
log config
hidekeys
username cisco privilege 15 password 0 cisco
interface FastEthernet0/0
ip address 10.108.255.10 255.255.255.240
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
speed auto
full-duplex
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 10.108.255.1
control-plane
voice-port 0/0
cptone GB
description UNDEFINED
voice-port 0/1
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.74.254.129
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.74.254.130
ccm-manager config
ccm-manager sccp local FastEthernet0/0
mgcp
mgcp call-agent 10.74.254.130 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp rtp payload-type nte 101
mgcp profile default
dial-peer voice 3371 pots
service mgcapp
port 0/0
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login local
transport input all
end
CUST6-VG202-MGCP#
CUST6-VG202-MGCP#
CUST6-VG202-MGCP#
CUST6-VG202-MGCP#
CUST6-VG202-MGCP#
CUST6-VG202-MGCP#
CUST6-VG202-MGCP#sh ccm-manager
MGCP Domain Name: CUST6-VG202-MGCP
Priority Status Host
Primary Registering with CM 10.74.254.130
First Backup Down 10.74.254.129
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 17:45:42 UTC Mar 3 2002 (elapsed time: 23:32:15)
Last MGCP traffic time: 17:17:55 UTC Mar 4 2002 (elapsed time: 00:00:01)
Last failover time: 17:01:14 UTC Mar 4 2002 from (0.0.0.0)
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Enabled/ON
Last MGCP Fallback start time: 17:47:30 UTC Mar 3 2002
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
FAX mode: cisco
Configuration Error History:
TFTP File download failed
CUST6-VG202-MGCP#ping 10.74.254.130
Sending 5, 100-byte ICMP Echos to 10.74.254.130, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 36/36/36 ms
01-05-2016 01:07 PM
Is the MGCP GW configured as "CUST6-VG202-MGCP" on CUCM? You need to make sure domain matches exactly, if you have domain name defined on the GW you need to include it as part of the name in CUCM.
01-07-2016 09:09 AM
Thanks Chris, now is working fine, the problem was related with a software installed in the middle which works with CUCM and there was the problem, not in the config.
regards.
01-07-2016 09:12 AM
Great, thanks for the follow up.
