Registering with SIP server using advanced IP services
dlewis006
I have been able to make my lab router send registration messages to a SIP server.  Is it a requirement to run from a CUBE IOS?  Software info below.    I am attempting to register using the information below.
sip-ua
 authentication username 8459997008 password xxxxxxxxxxxx realm voip.sotel.systems.com
 retry invite 3
 retry register 10
 registrar ipv4:4.28.93.140 expires 3600
voice service voip
 redirect ip2ip
 sip
Any help would be great....
Terry Cheema
Whats your current router model, IOS version? If you are on IOS 15.X you will need UC technology package installed (eval or permanent), CUBE needs licenses but its a Right To Use (RTU) license and will not stop you from configuring.
If you are on IOS 15.X and able to enter voice commands that means you already have proper IOS.
Still if you are unsure please post:
Sh version
-Terry
Edit: I overlooked the title of your post saying advanced services so appears you are on 12.X if thats the case see below:
Generally, for the Cisco 2800 and 3800 Series platforms, the Cisco Unified Border Element is supported on all Cisco IOS Software images of IP Voice and above. Specifically
1) INT VOICE/VIDEO, IPIP GW, TDMIP GW
2) INT VOICE/VIDEO, IPIPGW, TDMIP GW AES
3) INT VOICE/VIDEO GK, IPIPGW, TDMIP GW AES, LI
Terry Cheema
Sh version
-Terry
Terry,
Thanks for your quick response. Yes its on Advanced IP.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
I figured that I needed the Technology package as I have been able to get a CUBE to register with our service no problem.  I will see if I can get access to the Tech Package for my lab box.
