Matt Crosby
Beginner
Registration CUCM 9.1
How can I generate a report to see when a device was last registered with my call manager, even if it is currently not registered?
-Matt
1 ACCEPTED SOLUTION
Aman Soi
Advisor
Hi Jonathan,
U need to have 3rd party device to know the registration /un-regsitration status.You can visit www.variphy.com
You can also deploy Cisco Operations Manager .
regds,
aman
3 REPLIES 3
Aman Soi
Advisor
Hi Jonathan,
regds,
aman
Thanks Aman, for the reply and the variphy.com suggestion.
-Matt
Chris Deren
Hall of Fame Master
You can also look it up in RTMT.
Chris
Content for Community-Ad
Spotlight Awards 2021
