12-20-2013 01:13 AM - edited 03-16-2019 08:58 PM
Hi Team
Any Help on this
max phone exceed on UC 560. When i connect new phone. I need urgent help on this.
Solved! Go to Solution.
12-20-2013 06:56 AM
Hi Esa,
It sounds like a licensing issue to me. How many users is
the system licensed for and at what number of ephones are
you receiving the error?
"show lic detail"
"show platform software lic"
Cheers!
Rob
"When it comes to luck you make your own "
- Springsteen
12-20-2013 01:55 AM
Under telephony-service you can check with max-ephone how many phones you can add: http://cisco.biz/en/US/docs/voice_ip_comm/cucme/command/reference/cme_m1ht.html#wp1094681
If you can't add more, you need bigger router capable of registering more phones.
Check this link for specifications: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
You can have a look at this post as well:
https://supportforums.cisco.com/thread/2141447
Message was edited by: Hermanus Janse van Vuuren
12-20-2013 05:11 AM
Correctly said by Hermanus (+5).
In case the 'max ephone ?' command advises the number of phones you have configured already, then it is likely that we are running into a license issue.
In that case please share the output of 'sh license detail'.
It is possible that we might need to accept the EULA.
Please refer to the following for more information:
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155517
Sam
Please rate all helpful posts.
12-20-2013 06:19 AM
My ephone config is below
max-ephone 114
max-dn 600
So the max-ephone is not an issue. what will be reason?
pls assist.
It UC560 device.
12-20-2013 06:56 AM
Hi Esa,
"show lic detail"
Cheers!
Rob
- Springsteen
12-31-2013 02:45 AM
12-31-2013 08:19 AM
Hi Esa,
You are most welcome my friend
This does tell the story;
ASG-ASQ01-UC560#show platform software lic
License UDI : UC560-T1E1-K9:FGL154112G3
Maximum User Licenses : 22
Used User Licenses : 22
Available User Licenses : 0
As the uc560 has been announced as End of Life you will need to order
an add-on user license quite soon. Something like;
L-UC-PRO-8U= | Software license upgrade, authorizing an additional 8 users (e-delivery) |
End of Life notice;
Cheers!
Rob
- Springsteen
