04-23-2011 03:04 AM - edited 03-16-2019 04:39 AM
Hii All,
I'm working on some issue that our mgcp gateway (3925) registration.
All port show registered except EVM-HD-8FXS/DID on the module 2.
Any idea about this?
what i'm doing is.
Delete the module and re add the module.
Change the module from slot 1 to slot 2.
Unplug the module and plug the module.
use no mgcp and restart tftp service and then mgcp again.
manually put
dial-peer voice 999210 pots
service mgcpapp
port 2/0/0
but no of that is working.
Thanks before
Solved! Go to Solution.
04-24-2011 04:45 AM
@Pablo IMHO, FXS and FXO are supported using MGCP
/divin
But SCCP is superior, being specifically designed for phones.
04-23-2011 11:39 AM
You should use SCCP, not MGCP for FXS ports.
04-24-2011 01:45 AM
Hi Thanks for your response..
I have 3 E1 PRI port on that router too that already configure mgcp and working well.
And also fxo port configured and working well too.
Can we configure MGCP and SCCP in the same router ?
Thanks before
04-24-2011 02:07 AM
Please read answer above.
04-24-2011 04:17 AM
Verify the config...
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017825e.shtml
Make sure the hostname matches.
/divin
04-24-2011 04:45 AM
/divin
04-24-2011 07:21 PM
Hi Paolo,
I've already read your answer.
What I mean is can we configure SCCP and also MGCP on the same router?
Because on that router we've already configured as MGCP with 3 E1 and 11 Fxo port and working well already
Thanks before
04-25-2011 12:14 AM
Yes you can. You just have change the dial-peers for the FXO/FXS ports
Dial-peer voice x pots
Port 1/0/0
Service stcapp
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbasic.html#wp1010513
That's it
04-25-2011 03:25 AM
If you could not, I would not have suggested that, don't you think?
Thanks for the nice rating, and good luck!
04-26-2011 01:13 AM
Hi Paolo,
thanks, all port have been registered and working normally.
Hi dijohn.
thanks for the config guide
Tommy
