03-10-2014 12:30 PM - edited 03-16-2019 10:04 PM
Trying to figure out if it is possibe to release an extension for use again for auto-assign once a phone is unplugged. I test phones, mainly 79xx series, and it gets old fast having to do no ephone 1 2 3 ... when all of the extensions have been handed out.
03-10-2014 11:22 PM
Hi Zach,
I don't think such a functionality is feasible, as this would result is wiping out configuration even in case of following scenarios:
> ethernet cable gone bad
> someone accidentally unplugging the phone
> if the port to which the ip phone is connected is shut administratively or if it goes bad
Manish
03-11-2014 01:47 AM
Ah, understandable. Thanks anyway.
03-11-2014 07:01 AM
You could probably write an EEM or TCL script to remove the ephone configuration once the ephone unregistration log message is printed.
03-11-2014 09:28 AM
Never thought of that. Thanks for the idea.
