10-17-2012 02:11 PM - edited 03-16-2019 01:44 PM
Guys,
I have the follow problem with one onf my customers.
She has the remote destination feature configured and enabled for her mobile and desk phone.
When she receives call it rings first in her desk phone and after that it goes to her mobile, if her mobile is turn off the call goes directly to her mobile voicemail and not to her desk phone voicemail.
Is there a way to avoid that? Because if the mobile is turn off, the call should go back to her desk phone or her desk phone voicemail.
Thank you!
Solved! Go to Solution.
10-17-2012 07:36 PM
That you need to test with the mobile, as the Vm system usually answers right away you'll need to fine tune it by testing. If the vm from the mobile takes more time you'll need to change it and test
10-17-2012 05:50 PM
Configure the answer too soon timers, that's the purpose of it. You may read more about it on the CUCM 9 SRND.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-17-2012 06:05 PM
Thanks for the reply Jaime.
The answer too soon is configured with default values for both(1500 ms) and the Call Manager we are using is CUCM 6.1.5.
Which changes should I make it?
10-17-2012 07:36 PM
10-26-2012 08:58 AM
Hey Jaime,
Just changed all the values to the default and customer said that is now working fine.
Thank you very much for your help!
