Remove Cisco 100 NSE/8000
kimsengcheav
Does anyone know how to remove "rtpmap: 100 X-NSE/8000" and keep only "rtpmap:101 telephone-event /8000" in SDP message?
I have tried this "voice-class sip dtmf-relay force rtp-nte" but did not work.
I am using Cisco AS5400 Version 12.4(11)T4.
dial-peer voice 1798557 voip
 description Test via Testing
 translation-profile outgoing 389855
 huntstop
 preference 1
 destination-pattern 989610106
 voice-class codec 9
 voice-class h323 1
 voice-class sip rel1xx disable
 session protocol sipv2
 session target ipv4:xxx.xxx.xxx.xxx
 dtmf-relay rtp-nte
 Seng
Sreekanth Narayanan
Is there a reason why you are trying this? There is probably a different reason why the NSE header is added to the message. NSE is usually for modem/fax  communication. Can you include your show run in an attachment?
gabrielpetre
Did you find a solution for this issue?
Thanks!
