Remove filter in Active Directory synchronization with CUCM
yesenia-m
Beginner
Beginner
Hi team
Now I have in my CUCM the synchronization with AD, we configured a filter, this filter should be removed to pass all current database, but we know that in the CUCM or imply that we must take steps before removing the filter.
Thanks for your reply.
regards
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
No need to worry, you can safely remove the filter at any time without causing any issues.
HTH,
Chris
Chris Deren
Hall of Fame Master
HTH,
Chris
Hi Chris
Do I have to ask for a window of time to resynchronize all users?
Thank you
Not really, you can perform the sync after the change or you can wait until the next scheduled sync.
HTH,
Chris
