Remove Privacy from Jabber for Windows options
Nathan Compton
Enthusiast
Enthusiast
I have a customer requesting to disable Privacy so that users can not block users from adding them as contacts.  I see in the Jabber for Windows 11.0 deployment guide, you can do this in a Webex deployment:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/11_0/CJAB_BK_D657A25F_00_deployment-installation-guide-jabber-110/CJAB_BK_D657A25F_00_deployment-installation-guide-jabber-110_chapter_0110.html#JABW_TK_CF137A11_00
Is it possible to disable Privacy in an on-premises IM&P deployment?
Manish Gogna
Hi Nathan,
Officially its not supported, please check the following enhancement
https://tools.cisco.com/bugsearch/bug/CSCuo06018/?reffering_site=dumpcr
Jabber for Windows - Enhancement request to disable privacy settings
CSCuo06018
You can try an unsupported option though as explained in the following post
https://supportforums.cisco.com/discussion/11764816/removing-privacy-options-jabber-windows-clients
Manish
- Do rate helpful posts -
