05-10-2013 04:22 PM - edited 03-16-2019 05:16 PM
Is there any way to remove the "Clear" and "Delete" softkeys from "Missed Calls" and "Recieved Calls" directories?
I'm trying to do this on a 7965G with CUCM 8.6.2.
So far it just looks like you can set softkeys based on "call state".
Thanks in advance.
05-10-2013 10:01 PM
Unfortunately not, the pages are not editable as they are hard coded on the appliance CUCM server. You would need develop your own directory using Cisco's API.
HTH, please rate all useful posts!
Chris
05-13-2013 04:53 PM
Thanks for the reply Chris.
02-27-2014 03:27 AM
Dears;
but how we can to change the position of "clear" or "exit" soft key ??
BR
02-27-2014 06:09 AM
There is zero customization to the default pages, again you would need to develop your own.
Sorry :-(
Chris
