Remove "Clear" and "Delete" Softkeys from Directories?
sabbasaun
Is there any way to remove the "Clear" and "Delete" softkeys from "Missed Calls" and "Recieved Calls" directories?
I'm trying to do this on a 7965G with CUCM 8.6.2.
So far it just looks like you can set softkeys based on "call state".
Thanks in advance.
Chris Deren
Unfortunately not, the pages are not editable as they are hard coded on the appliance CUCM server. You would need develop your own directory using Cisco's API.
HTH, please rate all useful posts!
Chris
Thanks for the reply Chris.
Dears;
but how we can to change the position of "clear" or "exit" soft key ??
BR
There is zero customization to the default pages, again you would need to develop your own.
Sorry :-(
Chris
