Remove Self care portal login screen
Mike_P.
I need to remove (or at least turn off) the self care portal url. Does anyone know how I can do this?
I thought it maybe similar to the process of stopping the PLM service via CLI - but I couldn't find anything relating to Self Care Portal.
The ideal outcome would be when browsing to the CUCM address - the Installed Applications screen shows:
  • Cisco Unified Communications Manager
  • Cisco Unified Communications Self Care Portal
  • Cisco Prime License Manager
but when the user Clicks the Self care portal link they get a message similar to:
Cisco Self Care Portal was removed from this server by the system administrator on <date>. If you require further assistance please contact the system administrator.
Chris Deren
I am not aware of disabling it from within CUCM, but perhaps you can try doing it on DNS site by redirecting https://<CUCM host>/ucmuser/ to web page with the message you want to display.
Another option if you're running a proxy server is to block that URL.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Jaime Valencia
Self Care Portal is not a service, as all the other webpages, it depends on Tomcat.
There is no way to remove it when you browse to the ip/hostname/FQDN of the server.
java
if this helps, please rate
