Removing all ephone in one command
techguy
Level 4
Level 4
IS there any command which will delete all the ephone and ephones-dn & voice register pool from CME-SRST?
I wan to remove all ephone and voice registered pool information from my CME.
Hi.
To remove all ephone the commad is no telephony-service
To remove all register pools the command is no voice register global.
Those command will remove all cme and register config.
For srst config you should issue no call-manager fallback to remove the existing config
Carlo
Please rate all helpful posts "The more you help the more you learn"
I just want to remove ephones information in CME-as-SRST gateway so that next time in SRST mod it downloads all the ephone information again.
I am not using call-manager fallback but using telephony services. If i will do no telephony-service then it will remove also telephny service commands but i wan to remove only ephones.
Hi.
In this case, under telephony service remove command max-phone and max-dn and reload the VG.
Unfortunately to remove all pools under voice register global in one shoot, you have to issue the command no voice register global.
Carlo
