Highlighted
Contributor
Removing B-ACD from router running-config?
Is there any way to remove B-ACD from the running config, short of doing a write erase?
IOS is 12.4.20T and I can't change it.
With these commands B-ACD is still present in the running-config.
ROUTER(config)#application
ROUTER(config-app)#no service app-b-acd-aa
ROUTER(config)#no application
% Invalid input detected at '^' marker.
2 REPLIES 2
Highlighted
Hi Jason,
Looks like the router accepted the no service commands, are you still seeing those in the running config? It gives you an error when you try to do "no application". AFAIK, you dont need to do that to remove the BACD config and is not a valid command since application just brings you to the sub config mode of application to configure services such as BACD.
If I've misunderstood the issue, please elaborate further. HTH.
Harmit.
Highlighted
Rising star
Hi Jason,
There's not a easy way to do it, just need to remove all command used for BACD one by one.
You can use this guide to identify those commands:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40tcl.pdf
Favor calificar todos las respuestas útiles.
Please rate all useful posts
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
Content for Community-Ad
