Walkthrough Wednesdays
899
warquezho0612
Beginner
Removing/Uninstalling Network Locale in CUCM
I just installed a combined network locale in cucm, just to test different tones on different country. Now I want to remove it, is there a way to do so? Or it cannot be removed once installed?
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
Unfortunately there is no way to remove locales or COP files once they're installed.
There is already an enhancement request to find a way to do this but right now the only way is a reinstall.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
8 REPLIES 8
Jaime Valencia
java
java
When will they implement this new enchancement? So if I install a cop file network locale and then install a newer version of the cop file, will it replace the old one that I installed?
Thanks!
Jaime Valencia
No timeframes, it's just an enhacement request right now. If you're interested reach your AM so they can add you to the list of people looking for it.
Yes, you'll use the latest version you install
java
java
Thank you so much for you help! I just have one last question which I know is out of the topic but somehow related...
Is CUCM version 7 and above capable of defining the ring cadence? If yes where in CUCM can I set the ring cadence? I know I can do it on analog voice ports (fxs) on isr routers, I'm just wondering where in CUCM we set ring cadence for IP Phones and define a user defined ring candence..
Jaime Valencia
Go to the CUCM service parameters and look for the Call Classification parameter, this will slighlty change the cadence for off-net vs on-net calls.
That's as far as you can go changing the cadence for the ring in CUCM
java
java
so there is no way to set the cadence in CUCM like how we are setting it in the Router to have some fancy rings of short rings then long rings?
Like in the router under voice-port
"ring cadence define 50 1 50 1 100 1"
SERGIOGARAY
Beginner
delete cuc locale
This command deletes the specified locale and all of the associated files and settings from Connection.
delete cuc locale locale-id
@SERGIOGARAY wrote:
delete cuc locale
The OP question was for CUCM, not CUC.
Please rate all useful posts
Content for Community-Ad
Spotlight Awards 2021
