01-04-2016 03:48 PM - edited 03-17-2019 05:24 AM
is it possible to rename many users with BAT ?
Best regards,
Guillaume
01-04-2016 04:11 PM
Hi Guillaume,
Yes... just export users through bat,
Through excel modify the csv with desired values and import it back .
Than use BAT-->users-->update users ( custom file) to update desired users
Carlo
01-18-2016 03:39 PM
i want to say : i want to rename userid , i think it's not possible from BAT because BAT seems to use the userid as a primary key .
Guillaume
01-18-2016 04:00 PM
correct, BAT update used for modify any other fields apart from userid (like name, last name, phone number, etcc....) but not the USERID since it's the mandatory fields that's being used to update the CM DB tables.
Br,
Nadeem
01-04-2016 04:24 PM
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/bulk-administration-tool/110967-bat-00.html#update
